thwaites 4x4 aligator dumper
Discuss dumpers here
crew_cab
Real name: cath
Has thanked: 11 times
Post #1 by crew_cab » Thu Jun 15, 2023 3:21 pm
does anyone know where i can get a steering box for a thwaites 4x4 aligator dumper or where i can get one reconditioned
also looking for parts to convert to battery start or what to look for thanks
Has thanked: 854 times
Been thanked: 697 times
Re: thwaites 4x4 aligator dumper
Post #2 by essexpete » Thu Jun 15, 2023 4:23 pm
You ask at David Cornwallis, Thwaites specialist. I think the box is similar to the 2wd models, moving a spool valve in the case of the 4wd.Water ingress down the long tube may have been the problem. If the inwards are not completely shot, you might get away with bearings.
cobbadog
Real name: John
Has thanked: 303 times
Been thanked: 138 times
Post #3 by cobbadog » Fri Jun 16, 2023 6:54 am
As for electric start you need to tell us what engine, model and direction it rotates. Check to see that your flywheel does has teeth first not all did.
mechman
Real name: norman orrick
Has thanked: 149 times
Been thanked: 136 times
Post #4 by mechman » Fri Jun 16, 2023 11:33 am
Hi all.
I converted a Petters PH2 to electric start, I used a a donor engine for parts as mine did not have the starter ring Fly wheel. I posted the conversion on here. I think it comes under dumper TLC or Wingate 4s dumper. I had to fashion the tin work as there wasn't any made for that model.
Norm.
proglide1
Real name: john
Post #5 by proglide1 » Tue Aug 29, 2023 4:55 pm
I have an alligator that I'm using as a donor. Has steering box on but don't know if it's any good or not.
Very interested in the electric start option and details/ hints if anyone has managed to do one as struggling to swing the handle due to tendonitis.
Return to “Dumpers”
