The outer race of the bearing was stuck quite tight in the bearing holder, but some welding seemed to cure that issue.
Now i was very curious to check the gearbox. The cap over the gearbox seemed to never had been open since the birth of christ. I pulled the head of every screw. A good surprise though was that all the gear and bearings in there seemed to be in pretty good shape. But it was not much of oil in there.
Just some brown water mixed with oil at the bottom.
