DIY Pond Dredger in Design Stage
Discuss equipment which does not fit in in the other forums here, like cable cranes, material handlers, drilling, piling and screen equipment
joystick
Real name: Kieron Joy
Post #1 by joystick » Sun Aug 13, 2017 11:14 am
Product to be pumped:- Silt with no stones.
I am planning to construct a Dredger for a large pond. The raft will be constructed using wood and used 55l oil drums similar to on Youtube. The pump I have is a Hyundai DHY-T80E diesel driven 3" which can handle 20mm solids. The raft size is planned to be 1.5m x 2m approx. I would like to fit 4 ports on the suction side each selected in sequence by a flow driven rotational valve. The raft will be propelled forward by the suction force. The 4 ports will equal the width of the raft allowing it to cut through the silt at an adjustable depth. The silt will be pumped to one of three nearby islands to reduce the length of the flexible discharge pipe.
All comments will be gratefully received.
Joystick
hair bear
Real name: Rob
Has thanked: 206 times
Been thanked: 284 times
Re: DIY Pond Dredger in Design Stage
Post #2 by hair bear » Sun Aug 13, 2017 1:07 pm
Hi and welcome.
Interesting stuff, please keep us posted with progress, and of course, pictures!
Rob.
Land Rover
Real name: Gordon Short
Has thanked: 4 times
Been thanked: 13 times
Post #3 by Land Rover » Tue Aug 29, 2017 7:32 am
Bloody hell , sounds a good project .
If the silt is soft then it might bury the suction head into the silt and block it .
What would control the depth of dredge and rate of propulsion ?
Mrsmackpaul
Real name: Paul Griffiths
Has thanked: 384 times
Been thanked: 256 times
Post #4 by Mrsmackpaul » Tue Aug 29, 2017 11:27 am
is this similar to what is used for gold dredging ??
