https://ok.ru/video/1309621881488
Go to about 1hr 10 mins for some footage of classic 1950s icon (Miss Dors apart!)
Leyland Octopus
Re: Leyland Octopus
Thanks Pete,
Great video.
The old multi pull handbrake and that large diameter steering wheel brings back memories. You needed the big steering wheel then, the only power steering was your arms.
I worked on these back in the mid 60s and occasionally got to drive them. The firm I worked for back then had some Octopus flats and a couple of the slightly older model Ex BRS. These had servo brakes and I converted them to the more efficient "hydrovack" system like the later model.
All a very long time ago.
Great video.
Topic author - Posts: 4089
Re: Leyland Octopus
How did the multi pull work Fred?
I never understood Dad's AEC with a ratchet that was air operated.
Would that Leyland have really pushed over that rough ground or was that 1950s photoshop?
Re: Leyland Octopus
essexpete wrote:How did the multi pull work Fred?
Hi Pete,
I thought after I posted that someone may ask questions about the multi-pull brake.
The multi-pull was a rod operated hand brake with no power assistance, it therefore required a long lever to multiply, (gear down), the force exerted by the driver.
The lever, above its pivot, needed to be roughly eight or ten times the length of the short end below to achieve the pull required which meant that there was not enough travel at the short end to apply the brake.
The multi-pull allowed the driver to take about three pulls to build the amount of travel required without loosing effort. I'm struggling to explain the workings so I drew this rough sketch to help.
There is a quadrant linking the lever to the rod which operates the brakes. The quadrant has two pawl and ratchet arrangements.
The top one in the sketch engages the quadrant when the lever is pulled and the whole thing moves as one, pulling the brake on.
The quadrant, (bottom), pawl then prevents the quadrant slipping back keeping the brake on whilst the other pawl allows the lever to slip forward and latches on ready for another pull.
There is obviously a release mechanism. This operates when the lever is banged forward to the front of its travel. The release sounded like a gun going off.
I hope you can follow my ramblings.
- Real name: craig
- Has thanked: 156 times
- Been thanked: 374 times
Re: Leyland Octopus
Funnily enough The Long Haul was on the freeview channel Talking Pictures last week. Great channel for old British films and tv series on channel 85.
I enjoyed the film , first time I have seen Diana Dors in a film and thought she acted well.
Anyway back to Leyland Octopusi, on all the rough track scenes I noticed it had been fitted with military Trakgrip tyres on the rear bogie so I would guess it went up into the hills.
Craig
Craig
