Is there a trick to get JIC couplings to seal?
Just changed a deceased ram and the old couplings won't seal to the new ram. The ram fittings are identical from what I see but they just won't stop dripping.
Ideas anyone?
JIC couplings
- Real name: ian
- Has thanked: 126 times
Re: JIC couplings
Same as BSP (apart from the obvious differences). The sealing relies on the mating of the conical surfaces. If it's weeping, either the faces aren't mating correctly or the contact pressure is light.
If you are confident the thread isn't binding or similar, I'd loosen the nut slightly and with a tool on the ferule, work the hose back and forth as you tighten the nut. Hopefully you'll that'll reshape the mating surfaces.
Topic author - Posts: 1004
- Real name: Rob
- Has thanked: 206 times
- Been thanked: 284 times
Re: JIC couplings
Ok, so a closer look revealed that on the old ram the union nut has a couple of threads visible when tight and sealed (just refitted it to check). On the new ram the sockets appear slightly deeper and the nut is tight and threadbound before the union seals. I've contacted the supplier for suggestions so we'll see what happens.
- Real name: Rob
Re: JIC couplings
A quick update, and no further forward with this. The supplier was quick to respond and requested depth measurements of the ram sockets - no explanation of exactly how one would measure it taking into account the ram surface is a curved elipse and the base of the fitting is conical. A high precision screwthread depth micrometer is always in my tractor tool box...
- Real name: Chris
- Been thanked: 56 times
Re: JIC couplings
Hi hair bear. Can't you ask the ram supplier to send you some new couplings to suit the ram fittings and then have them grafted onto your existing hoses . That's assuming you have a bit of movement in the existing hoses ? Might be better than a constant drip ?
- Real name: Rob
Re: JIC couplings
It's worth a thought. Unfortunately the toys have had to take a back seat for a couple of weeks but hopefully I'll get back to it soon.
