I have a fiat 540, I serviced last month. used the tractor a few times and every time I check engine oil level I noticed that the level has increased to the stage that it is way past the full
level I am thinking it could be diesel don't know how. has any one else had that problem......
diesel in engine
- Has thanked: 1888 times
- Been thanked: 1705 times
Re: diesel in engine
vincem wrote:I have a fiat 540, I serviced last month. used the tractor a few times and every time I check engine oil level I noticed that the level has increased to the stage that it is way past the full
Hi Vince welcome to the site
- Real name: Trevor
- Has thanked: 71 times
- Been thanked: 42 times
Does it have a diesel lift pump on the block? Typically the diaphragm on those sort of pumps can become damaged and lets fuel slowly seep in.
Of course, it could also be water. How was the water level in the radiator?
TrevorJ wrote:Does it have a diesel lift pump on the block? Typically the diaphragm on those sort of pumps can become damaged and lets fuel slowly seep in.
Good call with the lift pump; however normally if water gets into the oil it usually forms an emulsified creamy coloured mess that's a dead give away.
- Real name: phil wheelton
It could be the seal at the front of the injection pump it can leak into the sump as well.
- Real name: Paul Griffiths
- Has thanked: 384 times
- Been thanked: 256 times
I have a 550 fiat and it has a lift pump on the side of the block would have thought yours would be the same should be a simple cheap fix from bearco or somewhere like that I would think the lift pump has a crook diaphram or seal but it would be cheaper just to replace
Good luck
http://www.ebay.com.au/itm/FPM3301-Fuel-Lift-Pump-Fiat-450-540-640-Tractor-580-680-780-60-90-70-90-80-90-/381112026092
Good luck
- Real name: Trevor
Jeremy, that's quite right most of the time. With water, most oils capture the water and discolour, but generally the engine needs to run first. When the engine has been sitting, and the water seeps in, the oil around the dipstick doesn't change that much, and carefully undoing the sump plug, will let most of the water leave without mixing with the oil too much.
Neoprene sheeting is pretty cheap to replace the diaphragm, if you don't mind getting your hands dirty.
Besides it may have a glass water separator on top, which are getting harder to replace.
![Wink ;)](./images/smilies/icon_e_wink.gif)
thanks every one for your answers,the water level is fine, the oil level is almost to top of dip stick
and is thinner than usual ,so I think I will replace the lift pump for a start , I shall also check power steering level . thanks again.............
- Real name: mark wignall
- Been thanked: 12 times
diesel can only enter the sump thru 3 ways .
lift pump seal fail
inj pump end seal fail ( asuming pump isnt shaft driven)
or down the side of boars when running ( this is very unlightly)
i know i had a inj seal fail on my loadall just after pump had been fully rebuilt
lift pump seal fail
the older the plant , the more i like it ,
im dislesik so escuse my spelin gramer
I crushed my spine years ago and im soposed 2 b in a wheel chair
so every day when i wake up and my legs still work is like crimbo day
Is the engine fitted with a diesel fueled heater on the inlet manifold? These type of heaters can break down and allow diesel to leak into the engine in some cases.
