JCB 3 1966 CYLINDER SEALS HELP REQUIRED
stewarty905
Real name: stewart
Post #1 by stewarty905 » Tue Jun 11, 2013 10:16 pm
Struggling to find the correct seal kit for the cylinder
I have fitted the rod seals part number 991/00003 they fit fine but the cylinder seal kit that came with it part number 2411/4009 does not fit ? Does anyone know the correct number i should be trying to get,they are old leather type seals for a 100mm cylinder.
philwheelton
Real name: phil wheelton
Been thanked: 29 times
Re: JCB 3 1966 CYLINDER SEALS HELP REQUIRED
Post #2 by philwheelton » Tue Jun 11, 2013 11:06 pm
Which ram are you working on and do you have the rod and cylinder size's
martyn williams
Real name: MARTYN WILLIAMS
Has thanked: 296 times
Been thanked: 359 times
Post #3 by martyn williams » Wed Jun 12, 2013 4:43 am
I managed to get matched seals for my machines from a Cardiff supplier, called Seal master, they were good quality and not a bad price.They supplied everything including scraper seal.
stewarty905
Real name: stewart
Post #4 by stewarty905 » Wed Jun 12, 2013 6:47 am
Phil the rod is 50mm,the cylinder is 100mm,I have done the rod seal thats all fine.
stewarty905
Real name: stewart
Post #5 by stewarty905 » Wed Jun 12, 2013 10:18 pm
This is a picture of the current seals
stewarty905
Real name: stewart
Post #6 by stewarty905 » Wed Jun 12, 2013 10:31 pm
another picture of seals only
smithhymac
Real name: morgan smith
Has thanked: 44 times
Been thanked: 13 times
Post #7 by smithhymac » Fri Jun 21, 2013 9:35 pm
hi there!, this seal type is called 'Chevron seals' and tha size is 3 5/8 inch bore, Manchester seals 01618327922 have these in stock! or at least they did last summer when I resealed the rams on my jcb 3! ask for sally she is very switched on!
Return to “Tech Talk”
