jcb2
Discuss loaders/backhoes here
rogerallum
Real name: Roger
Has thanked: 2 times
jcb2
Post #1 by rogerallum » Mon Jun 10, 2013 7:01 pm
Just bought a jcb with fordson super major skid unit.Just en-quiring age of the beast and whether its a JCB 2or 3. Backhoe has JCB2 stamped on it.Usual rusty cab but still digs well.
martyn williams
Real name: MARTYN WILLIAMS
Has thanked: 296 times
Been thanked: 359 times
Re: jcb2
Post #2 by martyn williams » Mon Jun 10, 2013 7:16 pm
Could you post some photos of it :thumbup:
TullyveeryClassicJCB
Real name: William Mulholland
Has thanked: 7 times
Been thanked: 43 times
Re: jcb2
Post #3 by TullyveeryClassicJCB » Mon Jun 10, 2013 8:39 pm
I make it between February 1964 - July 1964. The serial number should confirm the exact month.
William
JCB Hydra Digger Loadall 65
JCB 3DIII Powertrain
JCB 3DIII (Manual)
JCB 3DII
JCB 3CIII
JCB 805B
rogerallum
Real name: Roger
Re: jcb2
Post #4 by rogerallum » Mon Jun 10, 2013 8:57 pm
Thanks Martin for the prompt reply. I am a newbie at this, i looked on the jcb website & very confused :dizzy: what is recognized as a jcb 2 or 3?
Regards,
Roger
rogerallum
Real name: Roger
Re: jcb2
Post #5 by rogerallum » Mon Jun 10, 2013 9:11 pm
TullyveeryClassicJCB wrote:I make it between February 1964 - July 1964. The serial number should confirm the exact month.
Thanks William,I have posted some pics.Where would I find the serial no.
Regards
Roger
martyn williams
Re: jcb2
Post #6 by martyn williams » Mon Jun 10, 2013 9:50 pm
A nice project there, please keep us updated on your progress with it.
Re: jcb2
Post #7 by TullyveeryClassicJCB » Mon Jun 10, 2013 10:00 pm
The serial number on the JCB 2 was on top of the outer right hand side mudguard. Yours is definately a 2. Narrow cab as opposed to the wider cab of the JCB 3.
William
JCB 3DIII (Manual)
JCB 3DII
JCB 3CIII
JCB 805B
XS650
Real name: craig
Has thanked: 163 times
Been thanked: 388 times
Re: jcb2
Post #8 by XS650 » Tue Jun 11, 2013 11:21 am
Nice original machine , thanks for posting pics.
Craig
rogerallum
Real name: Roger
Re: jcb2
Post #9 by rogerallum » Mon Jun 24, 2013 8:06 pm
Update on my recent purchase.
Still very confused at correct age and whether it is a Super major or standard major engine.as serial no has been eaten by tin worm.Is there any easy way of identifying which engine it could be? Looked at a historical blog on this site which said jcb2 had a 3 cylinder engine and was manufactured between 1964-67.This is definitely 4 cylinders and Fordson.Just fitted new starter solenoid to avoid being squashed if left in gear whilst shorting out solenoid and depressing starter lever .at the same time! Shame all existing wiring has been disconnected and fuseboxes +key switch have been broken although voltage regulator has been re-wired albeit with conduit cable.Topped up hydraulic oil with 20 litres?,all rams closed.Fitted new rocker cover gasket and adjusted valve clearances.Found reason duty meter not working.inner cable removed so have installed complete new cable care of S.F.T (anti clockwise duty meter).Next job to clean all oil off radiator fins and flush radiator as water looks very brown.Loads of play in front left wheel bearing so steering very heavy and unresponsive one way. Once mechanicals are up to scratch i will attempt to tackle the tin worm
Has thanked: 1917 times
Been thanked: 1730 times
Re: jcb2
Post #10 by Jeremy Rowland » Tue Jun 25, 2013 6:39 am
The engine number should be stamped on the block somewhere, perhaps that may give you the lead that you are looking for? Just an idea?
Return to “Loaders/Backhoes”
Users browsing this forum: Bing [Bot] and 9 guests
