My JCB 3C mk111 Powertrain Build 5, now needs its ATF fluid topping up every time I use it.
Topic author - Posts: 3
- Real name: Don Cook
- Has thanked: 6 times
My JCB 3C mk111 Powertrain Build 5, now needs its ATF fluid topping up every time I use it. I can’t see an oil leak, so where is it going? When I bought it years ago, I was told to run the engine for a few minutes then check the oil, it has always been fine till just recently.
Re: My JCB 3C mk111 Powertrain Build 5, now needs its ATF fluid topping up every time I use it.
Run at fast idle for a few minutes then either dip whilst running or immediately on stop.
Does not take much to move a level on the dip stick. Don't overfill as it will blow out of the filler at best.
Could it be that the filter is blocked? I was thinking of changing it.
I might be wrong but I think the filter would by pass if blocked. It would not explain where the oil is going.
I was just wondering if it was backing up when running, so giving a false reading.
Well it could not hurt to eliminate the filter. If the transmission was leaking you should see it somewhere. As far as I can remember the gear box is not sealed to the shuttle but I guess you could check the gearbox level.
If the converter end was leaking I would think oil would be seen coming out of the bell housing.
Users browsing this forum: Google [Bot] and 18 guests
