The trouble with big loads can lead to big breaks,this 463 cracked through
the main tube,and with the weight wrenching it round and open,if we cant
get it welded back in place it means a new neck,but i know the man to ring
who has welded many a scraper back together
463H scrapers
- Real name: John Gaunt
Re: 463H scrapers
That's one serious crack you have there, Roly.
I'd be interested to see pics of the repair job if possible, before, during and after welding up.
I imagine that you'd need a special jig capable of exerting a lot of force to bring the two halves back together so that they can be welded, unless, of course you cut it right through.....what a mess!
In the second, third and fourth pics there is a small hole at the (top) end of the crack, presumably this was drilled to stop the crack going further ?
Topic author - Posts: 632
- Real name: Roly Billings
- Been thanked: 7 times
Re: 463H scrapers
nicky lamb wrote:Heck,I've never seen that happen before ,floors ripping up but not that!
Nicky,yes unusual place to crack,but it seem to start underneath where a hole big
enough to put your hand through had been gassed to drive out a sheave pin
when it was cable operated,our mistake for not welding it back up.
Re: 463H scrapers
John Gaunt wrote:That's one serious crack you have there, Roly.
John,the small hole you see goes with a row of them each side of the tube to
hold two rails for the block to slide each way with apron lift and ejecting a load,
i,ll update when it gets fixed
Re: 463H scrapers
Thanks,Roly, I can see the other 'holes' but with their bolts in when I look carefully at the first pic.
I believe that it's standard engineering practice to drill a (small) hole just beyond the end of a crack before welding up. This stops the crack spreading further.
The presence of that hole will have stopped the crack going further, and probably prevented catastrophic failure.
- Real name: Richard
- Has thanked: 28 times
- Been thanked: 46 times
Re: 463H scrapers
John Gaunt wrote:Thanks,Roly, I can see the other 'holes' but with their bolts in when I look carefully at the first pic.
I smiled when I read this.....reminded me of the welding tech. lecturer at college who explained this theory and said it was the reason why women have belly-buttons & *******s
- Real name: Peter
Re: 463H scrapers
Rolyd8k wrote:catpeter wrote:Hi Roly,
Nice pic's as usuall!
Is the snow gone?
Here we got some white shit last night!
Peter
Hi Peter,yes snows gone,but now got rain,but it should,nt hold us up
for too long
Hi Roly,
That 463 I posted some pic's of awhile back.....with in 2 week's it will be out earning it's keep!
Just a small job,about 2 week's!
But it's the first scraper job in the Stockholm area for almost 30years, for what I know at least.
Going to take an day of and take some pic's ofcourse!
Maybe even some film.
Cheers, Peter
Re: 463H scrapers
RichardJW~ wrote:John Gaunt wrote:Thanks,Roly, I can see the other 'holes' but with their bolts in when I look carefully at the first pic.
Richard,its a good job they drilled that extra hole nice one mate
Re: 463H scrapers
Cat-Peter wrote:Rolyd8k wrote:catpeter wrote:Hi Roly,
Is the snow gone?
Peter
for too long
Hi Roly,
Cheers, Peter
Peter,good luck with you new job hope it goes well,you will be showing a new way to
eartmoving,please put some pictures up
