Silencer wanted for JCB801
Are you searching for equipment?
Forum rules
[For sale]
[Wanted]
[Exchange]
[Swap]
Diggery
Real name: Ian Brightman
Post #1 by Diggery » Sat Sep 24, 2022 3:03 pm
Hi.
I have an early JCB 801. I think it's a 1989/1990.
I'm looking for a silencer, with gasket if possible. It's a 3 cylinder Perkins engine, serial number KD50316J24038S. Engine type is KD103.10. JCB list part number as 231/40007. I'm happy to fit an alternative that might need a little tweaking. All help very much appreciated.
Cheers
Ian
Has thanked: 854 times
Been thanked: 697 times
Re: Silencer wanted for JCB801
Post #2 by essexpete » Sat Sep 24, 2022 10:39 pm
Have you tried the nearest JCB agent for a starting point? You could try Vicary Plant. All spares seem expensive now.
Diggery
Post #3 by Diggery » Sun Sep 25, 2022 12:25 pm
Thanks. I've emailed Vicary, Dale is going to have a look tomorrow. It has split around the weld on the silencer/exhaust manifold flange pipe. This suggests a metal fatigue failure through vibration. I'm considering brazing it which would also, I think, anneal the silencer metal.
Post #4 by essexpete » Sun Sep 25, 2022 10:26 pm
Diggery wrote:Thanks. I've emailed Vicary, Dale is going to have a look tomorrow. It has split around the weld on the silencer/exhaust manifold flange pipe. This suggests a metal fatigue failure through vibration. I'm considering brazing it which would also, I think, anneal the silencer metal.
Are the engine mounts OK?
Diggery
Post #5 by Diggery » Mon Sep 26, 2022 7:39 pm
Yes. Two have recently been replaced. I suspect the failed mounts led to the metal fatigue. I've had it confirmed the silencer is now obsolete. I've also managed to get it welded.
Return to “Wanted”
