Hi knowledgeable people
I have a older fiat 640DT tractor and the manual I have says the power steering requires sate 20w oil. Trouble is I cannot find this stuff, does anyone know what I could use as an equivalent lubricant for this from the more modern ones available now??
Thanks in advance
Craig from nz
fiat 640dt power steering oil
- Real name: Trevor
- Has thanked: 71 times
- Been thanked: 42 times
Re: fiat 640dt power steering oil
You could ask your local oil disturber to see what they might suggest is suitable. Looking via google there doesn't seem to be a straight 20w engine oil available via a NZ website.
If straight 20w isn't available locally, I would suggest you find the nearest oil specialist store via the yellow pages and ring them. Some big automotive stores might be worth a shot as well.
[Unfortunately Castrol's web site is porked for older computer users but thankfully google's web cache was helpful.]
I've uploaded the specs for TECTION MONOGRADE 20W by Castrol. The NZ web entry for Castrol seems devoid of the product so you might need to order it.
- Been thanked: 192 times
Had a look in Morris Lubricants(it's a UK company) and for some reason they don't cover the older Fiat range but Universal (UTB) of Romania is there. The UTB 640DT is the same thing,built under licence, and Superfarm Universal 10w 30 is recommended for their PS system.
- Real name: Paul Griffiths
- Has thanked: 384 times
- Been thanked: 256 times
mate a would have thought any farm oil would be fine for those of you that dont know a farm oil can be used in the motor hydraulics and and gear box of almost all farm tractors
Castrol Agri
Gulf Western farm oil
most brands make something along those lines so you only keep one drum on the farm
Castrol Agri
