THWAITES SLIMLINE BRAKE CYLINDER
Posted: Mon Jan 22, 2024 5:00 pm
by BorryMB
Good afternoon, is there anyone who can tell me which brake cylinder I can order for a Thwaites slimline. the article number of thwaites is T50134, but it is no longer supplied, thanks
Re: THWAITES SLIMLINE BRAKE CYLINDER
Posted: Wed Jan 24, 2024 12:17 pm
by cobbadog
Not sure if this helps butgo to a brake and clutch repair shop to try and match the physical sizes eg, bore diameter and length. No sure where it needs to fit but it will be a start.
After that you will hav to machine one up from scratch using a piece of cast iron and start machining.
