Clutch
Topic author - Posts: 12
- Real name: Paul allen
- Has thanked: 6 times
Clutch
My clutch gave up today. I need release bearing cc8-14-16, pressure plate Borg & beck 45616 and clutch both & beck 52857. Anyone know where to get these?
- Has thanked: 303 times
Re: Clutch
Take them out, clean them up and drop them on the counter of your local clutch and brake shop, they will match it up for you.
- Has thanked: 1889 times
- Been thanked: 1705 times
Re: Clutch
Corranaheen wrote:If only it was that simple. Closest specialists I can find are in England.
Paul there must be somebody over there that fixes friction material to brake shoes/pads and clutches etc look or search for industrial brake repairs/specialists etc.
- Real name: Rob
- Has thanked: 206 times
- Been thanked: 284 times
Re: Clutch
Radius Components, Clondaklin, Dublin
Leixlip, Collinstown Co. Kildare
Blackheath Brake and Clutch, Dublin
Donedeal, Meath
Clarke Clutch and Brake, Lisburn
Donedeal, Meath
Re: Clutch
Any shop that sells clutches will have what you need, it is not a specialist thing. I go to the local shop for all the vintage tractor stuff and have never been disappointed.
Re: Clutch
I contacted Borg & beck who told me to order a 3 part clutch kit and they supplied the reference number. Ordered and it duly arrived. Pressure plate and release bearing as they should be. Driven clutch plate is not correct, the splined hole is too big. Hopefully Clarkes can help with a 10" plate 10 splines for 1" shaft. Thanks for all the help so far.
Re: Clutch
I'm sure they will correct the problem. Hindsight is a lovely thing and supplying parts is tricky and they should have asked you some basic questions so they sent the correct parts to you especially if there are products that look the same but are different like the spline size.
At least you are this much closer to being back in action.
Re: Clutch
Clarke clutch and brake made me the clutch disc in one hour for £60. Fitted it this afternoon and moved stones with the old girl tonight. Very pleased with Clarke’s, would highly recommend.
