Thwaites nimbus
Discuss dumpers here
Mickken123
Real name: Ken summers
Thwaites nimbus
Post #1 by Mickken123 » Mon Jan 14, 2019 6:09 pm
Hi everyone. Newby here . So I've just bought a thwaites nimbus not sure of year but around 60s me thinks. When I bought it the half shaft has been damaged so I need to know if these are still available and the brake shoe housing as this has been lost by previous owner . Any help would be grateful . Ken
cobbadog
Real name: John
Has thanked: 310 times
Been thanked: 139 times
Re: Thwaites nimbus
Post #2 by cobbadog » Tue Jan 15, 2019 3:33 am
Welcome to the Forum. It is a very helpful one but sometimes it takes a little time for the right bloke to log on and help but it will happen. Have you found any id tags anywhere on your dumpy? Type of engine and serial number as this can help date it. There is a supplier of parts in the UK and there is also workshop manuals available online using google and free. Make and model number will help reduce the options down to your one.
Hopefully you will get your answer and soon.
Cheers John
Has thanked: 2083 times
Been thanked: 1864 times
Re: Thwaites nimbus
Post #3 by Jeremy Rowland » Tue Jan 15, 2019 7:46 am
Hi Ken and welcome to the forum :wave: somebody on here should be able to give you the advice you are after; have a browse through the dumper threads you may find that the information id already on here, if I remember correctly I'm sure that somebody on here posted that Thwaites themselves are very helpful so that may be a starting point. :thumbup:
Mickken123
Re: Thwaites nimbus
Post #4 by Mickken123 » Tue Jan 15, 2019 5:40 pm
Hi Jeremy thanks for that . I'll call thwaites and see what they say in the meantime I'll have a good look through the dumper threads. Regards Ken
Mickken123
Re: Thwaites nimbus
Post #5 by Mickken123 » Tue Jan 15, 2019 5:45 pm
Sorry John didn't see your reply till I'd posted to Jeremy's reply thanks for your helpful post and I'll try and find as many I'd tags as possible. Regards Ken
cobbadog
Real name: John
Re: Thwaites nimbus
Post #6 by cobbadog » Wed Jan 16, 2019 4:50 am
You can't show too much info. The more the easier it is.
Moogy
Real name: Sev
Flag: Switzerland
Re: Thwaites nimbus
Post #7 by Moogy » Sun Jun 14, 2026 9:20 pm
Hello everyone,
I own a Thwaites Nimbus and am looking for tie rod ends / ball joints for the steering. When I measure the right-hand and left-hand threads on the tie rods, I get the following dimensions:
Outer diameter: 19.05 mm
Pitch: 1.5875 mm
Does anyone have any idea what type of ball joints these are and where I can get spare parts? Are they tie rod ends with a 3/4"-16 UNF thread?
Many thanks and best regards
freddyuk
Been thanked: 9 times
Re: Thwaites nimbus
Post #8 by freddyuk » Tue Aug 04, 2026 10:15 am
I am also doing the brakes and ball joints. The rear axle may be Vauxhall or Triumph Herald or Landrover. That is what I have gleaned so far.
I have had the original brake shoes relined but I need new springs so looking for the correct origin of the axle.
My brake rods are shot and have been welded together soI have bought some 8mm steel rod and will cut threads to fit the actuators. I have one new actuator and looking for another although the old ones still work just.
David Cornwallis is a source of info and some parts. Steering boxes are his speciality.
For the diesel Petter engine I recommend Paul at "realdiesels" who has all the parts.
Keep this thread going so we can all get these dumpers back on the road.
Return to “Dumpers”
