Wingett or thwaites dumper, repair drum clutch
Discuss dumpers here
Jonm
Real name: Jon Mabbett
Has thanked: 6 times
Been thanked: 11 times
Re: Wingett or thwaites dumper, repair drum clutch
Post #11 by Jonm » Tue Jun 05, 2018 7:05 pm
Unfortunately I cannot help with where to source clutch parts. Some years ago I obtained some engine gaskets etc from mead plant, email address then was info@meadplant.com
Regards
Jon
cobbadog
Real name: John
Has thanked: 310 times
Been thanked: 139 times
Post #12 by cobbadog » Sat Jun 09, 2018 6:21 am
Any brake shop would be able to re line your shoes and even bond oversize linings if required. As for the spring use Google to source a local spring manufacturer in the UK. One will turn up and you will be good to go.
I haven't seen a brake drum used as a clutch system before, even in the vintage tractors that we have.
Paulod1963
Real name: Paul O Dwyer
Has thanked: 8 times
Flag: Ireland
Post #13 by Paulod1963 » Mon Jul 16, 2018 10:41 am
Has anyone a picture of the clutch arm that fits into the thrust bearing .This is what's on mine when i bought it . It's a home made plug welded onto the arm is it right or wrong as i cant find a reference to the clutch arm on the net. Thanks again for your input Paul
Cheekymonkey
Real name: Pete
Post #14 by Cheekymonkey » Sat Nov 06, 2021 12:07 pm
Hi guys how on earth do you unscrew the conical nut? There's no head on it. Currently soaking in WD thinking I might have to grind flats on the head to grip?
Return to “Dumpers”
