Thanks guys. I am trying to find the seal kits before getting it out of the machine and apart. Does anyone know the model or series of these Staffa motors. I can’t seem to find any useful model number or info on the unit itself.
Dan
Hymac 580C slew motor seals
- Real name: Dan
- Been thanked: 5 times
- Has thanked: 1889 times
- Been thanked: 1705 times
Re: Hymac 580C slew motor seals
Dan I have spoken to Tony Flint he tells me there are two types of Staffa motor fitted on the 580C, either the B80 or the Mk7 and they are very hard to tell apart; Like Fred says he confirms that you will need a seal specialist so either Staffa themselves or get the seals made.
Topic author - Posts: 40
- Real name: alex smyth
- Been thanked: 16 times
The fact that there are two types of motor doesn't surprise me...it was the same with the cross-line relief valve..I may try to do it at some stage but for general clearing as I'm using the machine for at the moment, it's not insurmountable...
Just as a side thought....what would be the effect if I used a heavier hydraulic oil...i.e. 32 instead of 46?...would it tighten things up?
Heres the welsh dragon in the nest she is building...lol
- Real name: Matias
- Been thanked: 4 times
Hello!. good morning!
I have problems with the slew motor on my hy mac 610. Does anyone know what is the model of this slew motor?? HMB080?
When it takes temperature it loses power
Thank you!!
Thank you!!
- Real name: Håkan
- Has thanked: 46 times
- Been thanked: 26 times
Hi! Would be interesting to see a picture of your Hymac. Not everyday you see a wheeled Hymac. As far as i know the 610 is similar to the 580 model, but with other undercarriage, so the staffamotor should be the same. Dont know the part number, but i think Jeremy on this forum knows
- Real name: Matias
Andy80 wrote:Hi! Would be interesting to see a picture of your Hymac. Not everyday you see a wheeled Hymac. As far as i know the 610 is similar to the 580 model, but with other undercarriage, so the staffamotor should be the same. Dont know the part number, but i think Jeremy on this forum knows
Yes, no problem!
This is my machine:
https://www.youtube.com/watch?v=cjHqisifhTc
https://www.youtube.com/watch?v=jkP6xsAei60
https://www.youtube.com/watch?v=PFwmJTIeRaY
https://www.youtube.com/watch?v=BSSaWUKQJDA
These videos are from a few years ago. At that time I had problems with the slew motor, Jeremy and Fred helped me solve the problem
I stopped using the machine because I bought another excavator (doosan dx225lca). but now I need her again. That's why I want to see how I can solve the problem
- Real name: Matias
when the machine takes temperature it turns extremely slow and without power (the same problem as strontium90). I don't know if the problem is the seals or that the material is worn internally
maybe the slew motor is already obsolete and I have to get a new one
Contraband wrote:when the machine takes temperature it turns extremely slow and without power (the same problem as strontium90). I don't know if the problem is the seals or that the material is worn internally
Hi Matias I will be speaking with Tony Flint this week so I will see what he says.
- Real name: Matias
Jeremy Rowland wrote:Contraband wrote:when the machine takes temperature it turns extremely slow and without power (the same problem as strontium90). I don't know if the problem is the seals or that the material is worn internally
Thanks Jeremy!!
Do you know where I can buy the seals? Or the slew motor (Kawasaki Staffa)? remember that I live in Argentina
Maybe you could ask Tony about the transmission of my machine. Maybe he has some manual. the pinion and crown of a differential always breaks and I can't use it with the 4x4
Why? What is the original relationship of the differentials?
Matias the seals should be available online let me see what I can find out first.
