Hymac 580BT 1969
Discuss excavators here
Has thanked: 2071 times
Been thanked: 1848 times
Re: Hymac 580BT 1969
Post #191 by Jeremy Rowland » Mon Nov 20, 2023 8:33 pm
essexpete wrote:Where, out of interest, did you source the new rubbery gaters?
Pete they are not quite the right fit unfortunately but they came off EBay; I may order some mre but a slightly smaller diameter for hopefully a better fit?
Post #192 by Jeremy Rowland » Fri May 10, 2024 9:56 pm
Some half decent weather at last! :D I got up to my machines earlier this week, I did have one other previous visit where I did a small amount of cosmetic work on the Poclain. As many of you will no doubt be aware keeping machines outside they get covered in muck without doing any work, the 580BT looks rather weather beaten these days and was covered in a layer of muck that needed washing off.
I quickly got to work washing the machine down and the weather was perfect for this to be done, although we have had a few days of dry weather I didn't want to track either machine through mud to wash it off only to find it covered back in mud after I had tracked it back.
I do have a few days holiday due to me now so I need to get moving with some serious work, the Poclain also got another clean down.
Has thanked: 951 times
Been thanked: 786 times
Post #193 by essexpete » Fri May 10, 2024 11:27 pm
Brightening up J!
Post #194 by Jeremy Rowland » Sat May 11, 2024 7:47 pm
essexpete wrote:Brightening up J!
At long last! :thumbup:
Post #195 by Jeremy Rowland » Fri May 29, 2026 11:19 pm
Work has temporarily halted on the 690 for a couple of reasons, I'm still waiting on my fabricator to make the other panels I require and I still need to get three new hinges made, that aside I have turned back to do some more work on the 580BT. The side window rail where the two sliding windows are has rotted away, hardly surprising when you consider the machines age, I cleaned this up, got rid of the rotted metal and bolted a new strip of metal into place.
I considered if I should free off the sliding windows but after some serious consideration, I remembered all too well the horrible rattling noise they make when the engine is on tick over so I left well alone.
Return to “Excavators”
