Perkins heater pipe spigot thread
adg
Real name: Alistair
Has thanked: 9 times
Been thanked: 6 times
Post #1 by adg » Wed Jun 05, 2013 11:11 am
I would like to attach a heater feed from a Perkins 4.108 cylinder head.
There are two square headed blanking plugs at each end of the head and one temperature sender, these I'm told these are used for heater pipes when required.
Does anyone know what the thread pitch is for these plugs and where I might get some pipe spigots from?
Cheers
Al
martyn williams
Real name: MARTYN WILLIAMS
Has thanked: 296 times
Been thanked: 359 times
Re: Perkins heater pipe spigot thread
Post #2 by martyn williams » Wed Jun 05, 2013 3:56 pm
I have has problems getting pipe connections for fuel and oil pressure gauge fittings.Your local diesel specialist may be able to help.
Has thanked: 1295 times
Been thanked: 1111 times
Post #3 by FOWLER MAN » Sat Jun 08, 2013 12:46 am
I'm pretty certain the heater pipe tappings in the Perkins 108 head will be BSP, (British Standard Pipe). You will get a BSP fitting at any pipework supplier, hydraulic hose supplier or even a plumbers merchant. If you cant get exactly what you need get a fitting and get a tail welded or brazed onto it.
martyn williams
Post #4 by martyn williams » Sat Jun 08, 2013 4:59 am
Thats what I ended up doing, some are BSP but some have a very fine thread as on my Perkins 108 engined Hydrovane.My local supplier could not help with fittings for oil pressure gauges.Managed to get some connections off Ebay
adg
Real name: Alistair
Post #5 by adg » Fri Jun 14, 2013 3:53 pm
Thanks for the info gents.
It appears that the temperature sensor and the two blanking plugs are 1/2" BSPT. I'll know for certain after the weekend. As Martyn says, there are many fine threads all over this engine.
The engine in question is a 4.108 Perkins from a hydrovane. I'm using it to get a Kubota KH66 going, the previous owner only use the machine on rare occasions and when he did he used copious amounts of easy start :dizzy: . This looks to have promptly destroy all pistons/rings (Kubota parts don't come cheap) and is not an economic rebuild.
The drive coupling is centred and mounted on the flywheel and a bellhousing plate machined to fit and ready for the pump to be remounted.
I've made engine mountings and other bracketry. If I get a little time over the weekend, everything will be bolted and plumbed in ready for a trial. Once I know everything is working, I'll tidy the fabrications, spray the engine and put it back together...
martyn williams
Post #6 by martyn williams » Fri Jun 14, 2013 7:20 pm
Found some pipe fitting frrom Pertek Avonmout Depot :thumbup:
adg
Real name: Alistair
Post #7 by adg » Mon Jun 17, 2013 2:18 pm
Martyn, are these the oil preasure pipe fittings?
Great news if they are :)
martyn williams
Post #8 by martyn williams » Mon Jun 17, 2013 2:28 pm
Yes mate :thumbup:
Return to “Projects”
