With regard to your wiring in my manual on page 7-14. item 7 description is "thermostart" I've looked at other models and they list it the same. No glow plugs, I'm thinking "no start" if too hot
![Dizzy :dizzy:](./images/smilies/icon_shocked.gif)
James if you do disconnect the heat starting aid then it might be a good idea to make a mod and remove the fuel system from it. The reason I suggest this because they can leak fuel into the manifold when the engine is running. This can go unnoticed and make the engine knock under certain conditions and also cause diesel to dilute oil. I have had this happen of times over the years. Personally I would get the system to work as it can help to start more quickly on a very cold morning.
I also have the cold start knob at the top of the dash and I was wondering how that fitted into the picture too although mine appears to operate a bowden cable not a electrical switch? I cant see anywhere on the pump that it would connect though.
Good progress, I want to take my dash off now to fix electrical stuff and the steering wheel has already resisted two good pullers and appears to have no father. Did your's just pop off with a bit of assistance from a extractor?
