TD6 home at last
mambo
Real name: Brian
Has thanked: 8 times
Been thanked: 30 times
Re: TD6 home at last
Post #31 by mambo » Thu Aug 29, 2013 7:03 pm
Hi Martyn what's your process before painting?
Are you blasting and priming or just coating with a rust treatment?
martyn williams
Real name: MARTYN WILLIAMS
Has thanked: 296 times
Been thanked: 359 times
Post #32 by martyn williams » Thu Aug 29, 2013 7:33 pm
I take it back to bare metal by blasting or with brush / discs,then zink phosphate primer / red oxide after a degrease. one coat of undercoat and three top coats to finnish off , A good prep job is the key :thumbup:
I have found the grey phosphate primer the best. One machine was painted 12 years ago and no rust has come through even when the machine is kept outside in all weathers. The decals I use are also ver good with no degrade.
mambo
Real name: Brian
Post #33 by mambo » Thu Aug 29, 2013 8:10 pm
Ok thanks Martyn. I'm planning on getting my cab repaired soon, good info to bear in mind :thumbup:
martyn williams
Post #34 by martyn williams » Mon Sep 09, 2013 7:21 pm
Replacement parts for the starter motor have come from the USA, perhaps I can move the project on a bit now. It has been very busy in work though. Can't complain at that
martyn williams
Post #35 by martyn williams » Mon Sep 23, 2013 3:40 pm
Motor should be done this week,sideplate cut and drilled just needs final cleanup and prime.Seats done.Need to get the machine running and steering clutches freed off.If that works I will fit new brake linings.
Return to “Projects”
