TD6 home at last
bigkit
Real name: clive gray
Has thanked: 174 times
Been thanked: 242 times
Contact:
Re: TD6 home at last
Post #11 by bigkit » Sat Nov 10, 2012 11:01 pm
Is this to the next instalment in the C P and M! :o :thumbup:
Bit dis-respectful not getting your mate Graham to drop it off with the multi axle monster............it 'ave looked good perched on the wheel arch! :lol:
Good luck :thumbup:
martyn williams
Real name: MARTYN WILLIAMS
Has thanked: 296 times
Been thanked: 359 times
Post #12 by martyn williams » Sun Nov 11, 2012 6:21 am
I did think of getting Graham ,but getting his rig up my mates yard was impossible. :lol:It was tight enough with the transport I used,low power lines and narrow lanes. Saw Graham last week hauling another big load.
And yes it may be in a future CPM. :thumbup:
martyn williams
Post #13 by martyn williams » Sun Nov 11, 2012 9:12 pm
yippeeeee
Found a starter motor for it at last, it just needs refurbishing.
martyn williams
Post #14 by martyn williams » Fri Nov 23, 2012 8:22 pm
Started doing a bit more on the TD6 today, freeing up linkages and getting ready to overhaul the steering clutches and brakes.Heavy rain came in and stopped play this afternoon. :dizzy: Must get a shed sorted out.
martyn williams
Post #15 by martyn williams » Thu Nov 29, 2012 5:22 pm
Got the radiator shutters working as they should.Waiting news on the starter motor.Will be working on the diesel fuel system (looking for a fuel filter element ) on Friday, got hold of a good fuel tank and will overhaul the fuel lift pump.Had a good chance to make an assessment of this tractor.It will need its brakes relined as there is not much meat on the bands.Also its gauges renewing.Easier to work on than a tracked loader.
martyn williams
Post #16 by martyn williams » Tue Feb 12, 2013 3:22 pm
Got a starter motor at last. So when I have a couple of days off hopefullyI will get it running :thumbup:
martyn williams
Post #17 by martyn williams » Thu Feb 28, 2013 5:25 pm
Fitted starter,worked ok for a short while but needs a minor repair,hopefully.Started work on the running gear.Backed off the tracks a bit as they were too tight With the weather getting better hopefully will progress the restoration.
martyn williams
Post #18 by martyn williams » Tue Apr 09, 2013 11:32 pm
Motor now repaired after a replacement armature was sent from the states. Too longer screws were fitted by the chap in the U SA causing arking and damage to the armature.He supplied replacement parts for it.So hopefully progress will now be made.
martyn williams
Post #19 by martyn williams » Sun Apr 14, 2013 3:54 am
Motor repaired and works great now.Hopefully next week may get a start out of the tractor
martyn williams
Post #20 by martyn williams » Tue Apr 23, 2013 11:11 am
TD 6 engine is now running, but a small pin hole in plate behind the fuel pump needs to be sorted as is leaking antifreeze. A few small diesel leaks and the pin hole in the plate to do next. Ran well after many years of inactivity :thumbup:
Return to “Projects”
