JCB 801 hydraulic Spools/Valve
Posted: Mon Sep 14, 2020 5:38 pm
I had problems with the slewing on my JCB 801 machine. Being very old the clevis pins had worn that attached to the valve/spool assemblies. I stripped out the unit hat operates the dozer blade so I could get to the slew connections. I drilled out the holes on the arms to take larger clevis pins and take out the slack. On re-assembly a couple of months after I stripped it down, found there was a pin on the arm of dozer blade, it looks as though it should connect with the adjacent spool/valve arm, but the pin is too large to fit into the hole! For the life of me, cannot remember if it was or how it was fitted. as cannot find any left over bits (normally do). Would ally appreciate any advice, as I am stuck. I have attached some pictures that will hopefully show what I am trying to convey. Thanks, Terry
