John Gaunt wrote:Like the other guys Allistair, I'm VERY impressed with your standard of workmanship![]()
I'm curious to know what type of MIG wire you use for the hardened steel, presumably special composition rather than the "common'o garden" stuff I get for my home MIG ?
If I have to weld anything fancy, I use INOX DW rods and my stick welder.
just normal mild steel wire, but we dont weld really hard material, not easy a very involved process. we only weld semi hard materials such as hardox plate if you are familliar with it? just requires proper preheating and cooldown . the weld will assume the characteristics of welded material as it dilutes with it. if . to be honest im not technically knowledgeable , but i plan to do courses.
