HI EVRYONE
can anyone help, ive just bought an old 520 off ebay, the machine arrived today (i live in france)
it wasnt really as discribed , the back wheel looks about to collapse. i think its the top hat, kingpin thingy! the trouble is im not sure what its called does anyone know so i can dismantle and order one.any advice would be much appriecated.
CHEERS :
jcb 520 telehandler
- Real name: Mark Rive
- Has thanked: 33 times
- Been thanked: 26 times
Re: jcb 520 telehandler
Hi Jess, firstly I'm sorry your purchase is not what you expected I'm not exactly sure what you are describing as the fault, but, if you post up the serial number I'll extract the correct page from the parts manual and post it here. it will show a break down of the parts on the back axle and a list of part numbers Cheers Mark
- Real name: graham
- Has thanked: 97 times
- Been thanked: 74 times
there should be a plate top and bottom with four bolts holding it on ,with a grease nipple in the center
it will be the bearing /bush collapsed
if your a bit handy with spanners it's a self fix job
HI EVRYONE THANKS FOR ALL THE REPLYS ,ILL POST UP THE SERIAL NO ,AND YES IT IS 4WD. ANY IDEA HOW MUCH AND THE BEST PLACE TO GET POARTS IS?
CHEERS
JULIAN
CHEERS
JULIAN
- Real name: David Heighington
- Been thanked: 51 times
Hi Mark
Heres the serial no for the telehandler 520-4/501289 and the rear axle serial no is oooo7. it would be great if you could post the parts diagram.
Many thanks
Julian
Many thanks
Julian
jess wrote:Hi Mark
Many thanks
Julian
Hi Julian. This should do the trick. If not let me know! Cheers Mark
Hi thanks that is exactly what I was looking for Mark.
I am looking for jcb part # 448/04007 are these expensive to buy new would you know ?
