Hi thanks for replay I’m not that familiar with this but when I took the nut off only a plunger was there and a spring.
After taking them out I put the camera there, I never picked around to much.
I’ll try the gravity feed tomorrow
1988 JCB 3xc 4WD Grey Cab
- Been thanked: 191 times
Re: 1988 JCB 3xc 4WD Grey Cab
It does look like there is one....... Just be careful that the delivery valve body etc, doesn't come out wth the filter as there is a plunger that will fall into the hole and it can be a job to fish it back out..........
- Real name: dylan jones
- Has thanked: 40 times
- Been thanked: 33 times
Topic author - Posts: 36
- Real name: Gethin Davies
Yes there was a filter there. Managed to get it out, was clean. After trying the gravity feed and with little luck I gave up and put everything back, tried the lift pump again and that’s when I saw a leak coming out the pipe that runs from the sediment filter to the lift pump. Hopefully new pipe here will solve the problem.
Can anyone help with brakes on my 3cx
Iv changed the oil still making noice on both side Iv changed the pads and plates still making noise?? The old once were in good condition!! One of the pins holding the plate had a bit of play but fix that?
Any one got any ideas what els it could be
