The wiring under the machine, and a video of testing the right joystick.
And great thanks to Jeremy Rowland for your valuable help when working on the valves
https://youtu.be/OxFTXdMoZtU
New owner of Hymac 580B
Topic author - Posts: 101
- Real name: Håkan
- Has thanked: 45 times
- Been thanked: 25 times
Re: New owner of Hymac 580B
Finally the winter is over, the beautiful spring is here, i love it
As i said before i wanted to rebuild the sliding door and make it to the more modern model with hinges instead. With the new controls it would also give some valuable extra space in the cab.
Here comes some photos of the rebuild:
I also made a stop for the door
- Real name: Håkan
I also made a stop so i could lock the door open in summer.
During the winter i have had some problem with the starter. Sometimes when i turn the key nothings happened, just a click from the starter. I suspected a worn solenoid. Later it got so bad that i didnt make the machine start at all. So i ordered a rebuild starter from England, it was not cheap but only the best for my Hymac
With the new starter in place it stats up instantly every time
Now when the machine should be in good working order i had a friend to test the new controls. He is more used to operate diggers and me, and he said it was very easy to operate considering its age.
https://www.youtube.com/watch?v=Co-ywSlfvUk
I also have a question for Jeremy. In the manual i can read that you have to change or fill oil in the injection pump. Do you know where to fill?
Hi Andy nice to see the progress with your machine I must confess that I don't know where the oil goes in the injection pump I would imagine that there is a plug on the bottom half of the pump where the cam is? I think that Fred Evans would be the man to ask in this instance; Fred?
- Been thanked: 685 times
This might help although a 4 cylinder. Some of the engines I have seen lubricate from the timing chest others from oil within the pump.
Have you fitted servo controls to the old machine?
Had a quick look back and I see you are using a cable system a little like some farm loaders and hedge trimmers. Looks good, were the levers and cable expensive?
- Real name: Håkan
Thanks very much for the picture, i will compare this image to my pump and see
Yes i fitted cable control. I would estimate the cost for the whole rebuild to around 335£
After this rebuild the machine is almost as easy to operate as a servo controlled machine.
- Real name: Håkan
Time for a little uppdates. My Hymac is working well and are wery usefull
https://www.youtube.com/watch?v=XkdrkJ0PRKo
Andy she looks fine and works well once I have the Poclain 75CKB back up and running then I will be able to get back on with my 580BT
- Real name: Håkan
For being a machine from the 60's i'm very pleased with its capabilities
