The Early Days of Roadless Traction.
Discuss tractors here
Has thanked: 1295 times
Been thanked: 1111 times
Post #1 by FOWLER MAN » Thu Jan 07, 2016 10:56 pm
Following some interest in Roadless running gear in my recent post where I mentioned the Ransomes and Rapier crawler tractor I have done some research and this is what I was able to find out.
Roadless Traction Ltd. was started by Phillip Henry Johnson in 1919. He had at some stage worked for Fowlers so it's no surprise that the first example of Roadless tracks I could find was the steam powered Fowler Snaketrack from1920.
There were several examples of IC engined crawlers from established manufacturers of steam engines. Below is one from "Garret." The one pictured has a Barford and Perkins engine but later models were fitted with Gardner units.
And a single cylinder Marshall.
The Ransomes RT 50.
A Case.
And a couple of Fordsons.
Roadless running gear was fitted to the Ranomes MG and Bristol tractors too.
Has thanked: 853 times
Been thanked: 685 times
Re: The Early Days of Roadless Traction.
Post #2 by essexpete » Fri Jan 08, 2016 1:18 am
Thanks Fred!
Has thanked: 1873 times
Been thanked: 1692 times
Post #3 by Jeremy Rowland » Fri Jan 08, 2016 8:58 am
Great stuff Fred :thumbup:
Stormin
Real name: Norman
Has thanked: 2 times
Been thanked: 15 times
Post #4 by Stormin » Sun Jan 10, 2016 8:14 pm
Some great pictures Fred.
I'm wondering if the large diameter drive wheels are a result of the lack of track flexibility. Certainly the tracks seem to be hogging rather than sagging over the top of the return rollers. It could also to be to try and match the road speeds to the original tractors wheels and not necessitate a change in gearing.
hair bear
Real name: Rob
Has thanked: 195 times
Been thanked: 281 times
Post #5 by hair bear » Sun Nov 07, 2021 2:04 pm
Only just found this thread, so I'll add my pic (not that much of the running gear is visible!). I have the brass plate off the back somewhere that gives the track patent numbers on it. 1938.
prairie
Real name: Roger Haynes
Been thanked: 1 time
Flag: Canada
Post #6 by prairie » Fri Dec 10, 2021 11:08 pm
To add to this post, Col Johnson was involved in the designing of the first tanks in WW1. During the early 1990's, I had the privilege of owning original drawing's of Roadless going back to 1919, there being over 20,000 drawings. Col Johnson is also mentioned at the Tank museum at Bovington, and was designing flexible tacks in the early years, also rubber tracks in the 1920's. The drawings were certainly there, an english company way ahead of its time
Return to “Tractors”
