lancer Boss parts wanted
Discuss fork lifts here
john-joe
Real name: john
Post #1 by john-joe » Sun Nov 15, 2015 8:39 pm
I have a lancer boss HD 10 I think it is . I need parts for the brakes but don't seem to be able to find them . Any help would be appreciated
john-joe
Real name: john
Re: lancer Boss parts wanted
Post #2 by john-joe » Sun Nov 15, 2015 8:41 pm
If I knew the make and name of of that part I may be able to internet search for it
Has thanked: 1188 times
Been thanked: 1008 times
Post #3 by Jeremy Rowland » Sun Nov 15, 2015 10:03 pm
It may be worth your while searching for Lancer Boss/Lucas Girling brake components; that's the way that I would tackle the issue to start with, somebody is bound to have a kit for that master cylinder?
I would also look for local forklift truck agents/service they may just point you in the right direction or be able to supply you with the parts.
john-joe
Real name: john
Post #4 by john-joe » Sun Nov 15, 2015 10:40 pm
Jeremy Rowland wrote:It may be worth your while searching for Lancer Boss/Lucas Girling brake components; that's the way that I would tackle the issue to start with, somebody is bound to have a kit for that master cylinder?
Thanks Jeremy , I will try searching now . Do you think it's made by Lucas Girling ? . It's not the master cylinder . This is fixed on the back plate and operates the wheel cylinder mechanically
Post #5 by Jeremy Rowland » Sun Nov 15, 2015 11:11 pm
John-Joe I am only guessing by looking at the pictures that you have posted; I thought it was the master cylinder, however if it is a wheel cylinder or a master cylinder there is a good chance that it was made by Lucas Girling because they made brake components for many different applications amongst other things too. Good luck with your hunt!
mynachdy
Real name: Mike
Been thanked: 2 times
Post #6 by mynachdy » Fri Dec 04, 2015 11:01 am
Give us the full serial number and I should be able to help you.
Mike
edenboy
Real name: kelvin hammer
Has thanked: 1 time
Been thanked: 3 times
Post #7 by edenboy » Tue Jan 10, 2017 10:32 pm
Hi, have you sorted this yet? If you try HTS in Luton they have parts which they bought off Lancer Boss in Leighton Buzzard. If they haven't you can strip the thing down and see if there's a part numbers on the u cup oil seals which you will be able to match up on line. You'll probably fine it's the make Lockheed or something. If you can get seals you'll need to purchase a mini honing tool to smooth out the cylinder and remove any rust. After that it will need polishing. I used a drill bit in a drill with a rag round it and a bar of metal polish. Worked a treat. Hope that helps. One other option it to use a land rover or MGB master cylinder and adapt the pipe fittings.
Return to “Fork Lifts”
