Hi All,
We have just purchased a mini digger which we are led to believe is a Volvo Peljob 1 ton powered by a 2 cylinder diesel engine. It looks an old machine but digs quite well even tough there is a considerable slop in the bushes. It also has a lot of movement in the slew.
Please can anyone advise how we tighten the movement in the slew, and where would I be able to obtain a manual on this machine
Many thanks
Jeff
Mini Digger
- Real name: clive gray
- Has thanked: 174 times
- Been thanked: 242 times
Re: Mini Digger
Hi Jeff, try volvo for a manual, digbits offer cheap aftermarket pins and bushes that should do you. As for side play, well more importatent it has n't got up and down play in the slew ring. Grease it up well and give it a go. Slew rings are available service exchange. The side play maybe down to the slew motor, check its bolted up tight. Good luck.
Re: Mini Digger
bigkit wrote:Hi Jeff, try volvo for a manual, digbits offer cheap aftermarket pins and bushes that should do you. As for side play, well more importatent it has n't got up and down play in the slew ring. Grease it up well and give it a go. Slew rings are available service exchange. The side play maybe down to the slew motor, check its bolted up tight. Good luck.
Thanls Clive
- Real name: mark wignall
- Been thanked: 12 times
Re: Mini Digger
if its a rubber track some ware on it will b a size
but if you get on 2 digger bits they shuld be able to sort you out with what you nead to do
the older the plant , the more i like it ,
im dislesik so escuse my spelin gramer
I crushed my spine years ago and im soposed 2 b in a wheel chair
so every day when i wake up and my legs still work is like crimbo day
- Real name: Richard
- Has thanked: 530 times
- Been thanked: 177 times
Re: Mini Digger
These guys might be able to help, I used them years ago give them a call for advise
http://www.southernplantspares.com/rubber-tracks.html
