thwaites brake parts
Discuss dumpers here
Sven-Erik
Real name: Sven-Erik Larsen
Post #1 by Sven-Erik » Tue Feb 04, 2014 10:44 pm
Hi need some brake parts master cylinder and caliper rebuild gaskets,
for my 1976 4x4 Thwaites 3 ton .where can i get thees parts anyone ?
Has thanked: 854 times
Been thanked: 697 times
Re: thwaites brake parts
Post #2 by essexpete » Tue Feb 04, 2014 11:50 pm
Is that really only a three ton machine? It looks huge.
I would guess that Thwaites would have used an off shelf type product/fitting that would have been used elsewhere. If someone could identify the parts with numbers you could widen the search. Are they Girling or Lockheed?
Sven-Erik
Post #3 by Sven-Erik » Wed Feb 05, 2014 6:22 am
Hi, it is a 3 ton after the machine number.
I havent seen the brand of brake system yet.
The machine is new to me.
Sven-Erik
Post #4 by Sven-Erik » Sun Feb 09, 2014 5:47 pm
I have now found out it has Dunlop calipers and girling master cylinders, how can i find out what kind of fluid to use in my system Brake fluid or mineral oil ? there looks to have been mineral oil not brakefluid that came out when i did disassembly
of some of the parts today.the cap on the fluid reservoar is gone. the pistons in the master cylinder is stuck, and one of the brake hoses is clogged .here is a Picture of the machine It says hydraulic system mobil dte oil,no mention of brake fluid.
Thanks for all help you can give me.
Post #5 by essexpete » Sun Feb 09, 2014 10:42 pm
I would do a search starting with :https://www.google.co.uk/search?q=old+girling+master+cylinder&source=lnms&tbm=isch&sa=X&ei=fv33UuX7Hobe7Aad-ICYBw&ved=0CAcQ_AUoAQ&biw=1440&bih=658
I would guess you might have to dismantle and clean, replace all the seals if it has stood for a long time. If the bores are corroded then some kind of replacement will be needed.
Maybe this might help: http://www.powertrackbrakes.co.uk/caliper.html
I would think you need to stay clear of the modern brake fluids as most like they will damage seals.
Sven-Erik
Post #6 by Sven-Erik » Mon Feb 10, 2014 6:33 pm
I got a mail from Thwaites that told me to use brakefuid on my machine.so that
part is solved.
Sven-Erik
Post #7 by Sven-Erik » Sat Mar 01, 2014 7:34 pm
I now have repaired the brakes on the machine, and they work well.
I have also overhauled the lift cylinder and tilt cylinders, and replaced all the oil, I have trouble getting me new hydraulic filter but I'm working on it.
If anyone knows of a filter with measures 10 "high 2" internal diameter and about 3.5 "
outside diameter, oil supply in the center so let me know.
I have no got a New filter, tested the lifting of my 820kg log machine ,no problem
Regards Sven-Erik
Return to “Dumpers”
