Hi everybody
I 'm from Sweden and new at the forum. My school english is not up to date but i hope you will understand me anyway.
I considering to by an JCB 3C Mk II. The tractor has two known problems, it won't start and the gearbox is damaged.
The starting problem is probably not a big deal, the current owner have not used the tractor since 2010. When he parked it the engine worked fine, my guess is that is something with the fuel supply. Mayby dirt in a fuel hose or in a filter.
The problem with the gearbox is another story. Not a single gear is working (the current owner pushed it with a digging machine).
Probably i have to replace the gearbox or renovate it.
Is it a big job job to replace it? Or is it a better solution to renovate the gearbox?
Are there some known "standard problems" with the gearbox in these models?
I would be thankful for any advice....
Problem with the gearbox, JCB 3C II
- Real name: phil wheelton
- Been thanked: 29 times
Re: Problem with the gearbox, JCB 3C II
The 3 at the end of the serial no means it has a torque converter if this is the trouble with the gearbox it can be a costly and big job to fix you need to have it running to see where the problem is!...
Thanks for the answer Phil.
I have a price from a supplier in UK for a used gearbox (£600). Shipping to Sweden about £150. But i dont know the price for a converter.
- Real name: Rainer
Hello,
why do You think it is the converter or the gearbox? It also can be broken Diff or a broken axle.
Rainer
Rainer
Users browsing this forum: chrislovett62 and 50 guests
