i am trying to order a gasket kit for my jcb 3c, how do i know if the engine is a 38td or a n.98
here are the specs on the machine
jcb serial # 10764313
tractor #384b 190434
engine #21264
What engine is in my jcb 3c?
- Real name: john
Re: What engine is in my jcb 3c?
ken1953 wrote:i am trying to order a gasket kit for my jcb 3c, how do i know if the engine is a 38td or a n.98
engine #21264
Hi Ken1953
Those numbers are so close to mine
Mine are:
jcb serial # 109278 blank
tractor #384b 192903
engine #23708
So your must have a torque converter, I am guessing from the 3 at the end of the JCB serial #
Any way check if three injectors or four, that is a good start.
Hopefully one the more knowledgable posters will reply.
I would love to know the year of mine
Have you any photos?
John
Topic author - Posts: 29
- Real name: ken pearcey
just reading the manual and the 38dt is identifiable by serial number and the 4/98 is a number prefix does anyone know what this means?
I think 4 is 4 cylinder and 98 is developed torque, 4 /98 but I may be wrong
- Real name: john
- Been thanked: 6 times
engine #21264
You can download the manual for the 38TD and 4/98NT here
downloads.php?cat=5
this should help to identify your engine
did your engine boil over? is the thermostat missing? read this
http://leyland.conforums.com/index.cgi?board=general&action=print&num=1249737200
1982 3CX4 sitemaster
- Real name: john
engine #21264
downloads.php?cat=5
- Real name: Mark Rive
- Has thanked: 33 times
- Been thanked: 26 times
engine #21264
Here you go, JCB P'Nos: Head kit (Decoke) only 813/00268. Complete kit (less decoke kit) 813/00205
engine serial number is 498TBAK124, got the head kit on order from a tractor supply company here in St.John's, got the water pump and gasket kit for 160, JCB dealer wants 250 just for the gaskets.
The reason i am taking the head off is that she is putting compression in the rad and there was no thermostat. Put a new thermostat in and still the same problem. As soon as i start the engine the radiator pressurizes.
- Real name: R
- Been thanked: 191 times
B100 LOADER wrote:I think 4 is 4 cylinder and 98 is developed torque, 4 /98 but I may be wrong
4/98 is 4 cylinder and 98mm bore. 3.8 is engine capacity in litres. The engines in early mark 2 3c's,were known as 3.8 BMC which were 4/99 ie 4 cyl and 99 mm bore.Later mk 2 and onward to mk 3 and 3cx had the newer engine-known as 4/98. (Although,am nearly sure they were around 3.8 litre too!).
