Joe, super glue is ok, but for a slightly stronger bond use Cyano, best known product name is "Rocket" but there are many names on the model shop shelf, it can come in three grades, thin, medium and thick, use the medium for general use .. it is slightly more runny than super glue
As for the sanding boards, yes thats exactly what they are, they are thicker than emery boards, with a plastic middle ..they cost about £1.50ish each .. you can find them at most good independent chemists...
All my masters are made out of plactic card ..here is a picture of the 1/35th scale Hymac masters under construction
