JCB 3CX Gearbox Shaft seal leak?
Discuss excavators here
Classic3CX
Has thanked: 13 times
Been thanked: 4 times
Re: JCB 3CX Gearbox Shaft seal leak?
Post #11 by Classic3CX » Thu Jun 25, 2020 4:59 pm
I have tried but often comes up with engine oils instead and the machine is that old it doesn’t list it
Has thanked: 853 times
Been thanked: 684 times
Post #12 by essexpete » Fri Jun 26, 2020 10:23 am
JCB 3cx fluids
Try that link from a post by Topkit.
Classic3CX
Post #13 by Classic3CX » Fri Jul 17, 2020 12:15 pm
Tried that too but doesn’t come up with a spec, I know it just says JCB special transmission oil in the manual, could anyone recommend one to use for a 1987 machine?
agrimax
Real name: R
Has thanked: 14 times
Been thanked: 191 times
Post #14 by agrimax » Sun Jul 19, 2020 1:58 pm
Morris Terrain CT10 is the correct equivalent to JCBs Special stuff. Any that I know of with the Sychro Shuttle transmission have standard ATF Dextron 11.
Classic3CX
Post #15 by Classic3CX » Sun Jul 19, 2020 10:14 pm
Ah ok, thanks for the info on that one, how can you tell if a machine has a synchro shuttle? I’m pretty sure mine has that, with the manual 4 speed to select gear first then just forward/reverse on the stalk.
Post #16 by essexpete » Mon Jul 20, 2020 9:06 am
That sounds right. Some later options dispensed with the gear lever and had an electrically controlled power shift operated by the collar on the shuttle stalk.
Classic3CX
Post #17 by Classic3CX » Sat Jul 25, 2020 12:40 pm
Oh I see. I have found some oil for a decent price and was wondering on peoples opinions if it would be suitable, I have also included a photo of the stalk set up. Any help is appreciated on this :)
agrimax
Real name: R
Post #18 by agrimax » Sat Jul 25, 2020 9:27 pm
You have Synchro Shuttle as the stalk is a switch that operates solenoids on the top of the transmission. The older models with Borg Warner torque converter had a long,near vertical lever that operated a cable to mechanically move a valve for f/n/r. That oil will be fine too...
Classic3CX
Post #19 by Classic3CX » Thu Aug 13, 2020 9:07 pm
Just wondering if there is anything I’ve missed or worth looking at on this. Managed to change the lip seal on the gearbox and also the filter which needed a clean, also replaced with new gasket, also seen the transmission gears which looked fine, I presume I may have to drain the transmission oil cooler at the front of the machine to get any residual oil out as so far drained around 12 litres. See photos below :)
Ryan58
Real name: ryan peter
Has thanked: 2 times
Post #20 by Ryan58 » Fri Oct 02, 2020 1:37 pm
Did you get it checked from some reliable heavy equipment mechanic and how bad is the leak is it constant or just while on work
Return to “Excavators”
