Clutch
Discuss dumpers here
Corranaheen
Real name: Paul allen
Has thanked: 6 times
Been thanked: 2 times
Flag: Ireland
Clutch
Post #1 by Corranaheen » Fri Jun 05, 2020 8:16 pm
My clutch gave up today. I need release bearing cc8-14-16, pressure plate Borg & beck 45616 and clutch both & beck 52857. Anyone know where to get these?
cobbadog
Real name: John
Has thanked: 302 times
Been thanked: 138 times
Re: Clutch
Post #2 by cobbadog » Sat Jun 06, 2020 8:23 am
Take them out, clean them up and drop them on the counter of your local clutch and brake shop, they will match it up for you.
Corranaheen
Flag: Ireland
Re: Clutch
Post #3 by Corranaheen » Sun Jun 07, 2020 12:29 am
If only it was that simple. Closest specialists I can find are in England.
Has thanked: 1875 times
Been thanked: 1692 times
Re: Clutch
Post #4 by Jeremy Rowland » Sun Jun 07, 2020 11:59 am
Corranaheen wrote:If only it was that simple. Closest specialists I can find are in England.
Paul there must be somebody over there that fixes friction material to brake shoes/pads and clutches etc look or search for industrial brake repairs/specialists etc.
hair bear
Real name: Rob
Has thanked: 195 times
Been thanked: 281 times
Re: Clutch
Post #5 by hair bear » Sun Jun 07, 2020 3:09 pm
Radius Components, Clondaklin, Dublin
Leixlip, Collinstown Co. Kildare
Blackheath Brake and Clutch, Dublin
Donedeal, Meath
Clarke Clutch and Brake, Lisburn
cobbadog
Real name: John
Re: Clutch
Post #6 by cobbadog » Mon Jun 08, 2020 7:36 am
Any shop that sells clutches will have what you need, it is not a specialist thing. I go to the local shop for all the vintage tractor stuff and have never been disappointed.
Corranaheen
Flag: Ireland
Re: Clutch
Post #7 by Corranaheen » Sat Jun 13, 2020 6:04 pm
I contacted Borg & beck who told me to order a 3 part clutch kit and they supplied the reference number. Ordered and it duly arrived. Pressure plate and release bearing as they should be. Driven clutch plate is not correct, the splined hole is too big. Hopefully Clarkes can help with a 10" plate 10 splines for 1" shaft. Thanks for all the help so far.
cobbadog
Real name: John
Re: Clutch
Post #8 by cobbadog » Sun Jun 14, 2020 8:03 am
I'm sure they will correct the problem. Hindsight is a lovely thing and supplying parts is tricky and they should have asked you some basic questions so they sent the correct parts to you especially if there are products that look the same but are different like the spline size.
At least you are this much closer to being back in action.
Corranaheen
Flag: Ireland
Re: Clutch
Post #9 by Corranaheen » Mon Jun 15, 2020 10:25 pm
Clarke clutch and brake made me the clutch disc in one hour for £60. Fitted it this afternoon and moved stones with the old girl tonight. Very pleased with Clarke’s, would highly recommend.
cobbadog
Real name: John
Re: Clutch
Post #10 by cobbadog » Tue Jun 16, 2020 12:49 am
Well done, we are glad you are back in action. Sounds like good service.
Return to “Dumpers”
Users browsing this forum: No registered users and 27 guests
