Manitou mb25 forklift
Hi all I have a 1982 rough terrain manitou have a problem with the mast/forks as they are stuck 7 ft in the air they will go higher but come to a definitive stop have tried putting a ton weight on them but still the same everything else works silt & side shift has anyone got any ideas thanks
- Real name: Rob
- Has thanked: 195 times
- Been thanked: 281 times
Re: Manitou mb25 forklift
Not familiar with these but it sounds like the mast has over reached and the telescopic bit is out of it's guide rail, or it's reached past a 'stop' and can't return. Best I can suggest is park it with the forks over a lorry bed or similar as you can inspect it without a ladder, you're not under it if it drops, and if it drops it's not the full seven feet damaging itself.
I'm sure someone else will have a better idea.
check the 2stage there's a problem there?
disconnect the hydraulics,CAREFULL!!
If it doesn't come down it's mechanical.(mastrols?) if it does come down you should check you're hydraulic hose's etc
Thanks for replys drained hydraulic oil yesterday then took hose off main ram & it's still stuck tried again before draining down was going even higher so stopped as its over 7 ft high now as ram was going up was sticking & jumping as it was moving,so what are the mastrols ?
- Has thanked: 1875 times
fordf100 wrote:Thanks for replys drained hydraulic oil yesterday then took hose off main ram & it's still stuck tried again before draining down was going even higher so stopped as its over 7 ft high now as ram was going up was sticking & jumping as it was moving,so what are the mastrols ?
I am assuming that the mastrols are the parts of the jib that the sliding jib fits in? Could also be the ram itself if its a telescopic ram? Just a couple of ideas, if it isn't a hydraulic problem then it can only be a mechanical one making the jib jamb.
When you took the hose off the ram is there any kind of safety valve there because that could also be holding any hydraulic oil in the ram holding the whole thing up.
If you are sure that you have drained all of the oil from the ram then be very careful when you try to bring it down as there will be nothing to stop it from crashing down.
Beginning to think it's the mast bearings so I'm going to drop mast down on floor then take main ram off & see initially thought hydraulic filter or pipes were blocked & not letting oil return but now I've drained it & filter off & both look new so beginning to think last owner thought this too
fordf100 wrote:Beginning to think it's the mast bearings so I'm going to drop mast down on floor then take main ram off & see initially thought hydraulic filter or pipes were blocked & not letting oil return but now I've drained it & filter off & both look new so beginning to think last owner thought this too
With the mast dropped to the floor and the ram removed you should easily locate the fault which I suspect is more than likely to be mechanical and not hydraulic; good luck let us know what you find?
Right finally got it sorted dropped the mast out & stripped it took out jib & found bearing had been running on edge of mast & bent out so it was binding got it out massive amounts of heat hammered it back did manage to bend it on the length so had to straighten that got it all back in & it's working great now thanks to all who replied
