Page 1 of 5
Hunslett shunter
Posted: Tue Apr 24, 2018 7:21 pm
by mechman
Hi all.
Was asked to have a go at getting this running. It's was made by Hunslett about 1961, It's believed to be the only one of its kind (small Dorman 4 cyl)left. Water pump, core plug and smashed fuel filter on todays medical, the motor isn't seized though. I'll see what else later. Oh by the way that Winget dumper is still on going.
Norm
Re: Hunslett shunter
Posted: Tue Apr 24, 2018 9:10 pm
by mechman
Forgot to mention the loco is driven from out side the cab. the driver stands on the running boards (on either side) and controls the loco by controls (Duel) just inside the cab door.
Posted: Wed Apr 25, 2018 7:27 am
by Jeremy Rowland
mechman wrote:Hi all.
Norm
That sounds like it's not the hardest of jobs to fix Norman let us all know how you get on with it.
Posted: Tue May 01, 2018 9:31 pm
by mechman
Took some pics of the Hunslet topless today, one of the pics you'll notice the fuel filter with the snapped centre bolt, one of the lads is knocking a new one up, Its a bit special with a 3/8" BSF thread with a 7/16" BSW head, 4" long with a circlip groove in it. the filter is a Purolator.
Norm.
Posted: Wed May 02, 2018 7:06 am
by Jeremy Rowland
Nice one Norman
yes the easier solution to the snapped filter bolt is to either make a new one or replace the whole unit with a more modern filter.
Posted: Thu May 03, 2018 9:04 pm
by mechman
I would normally swop it out but the fuel pipes have large nuts on them and the ends of the pipes have those brazed on type fittings, it's not going anywhere soon so I'll carry on with the water system. The loco doesn't have any gears just forward and reverse, it has what looks like a torque converter or fluid fly wheel on the box so I'm surmising that It's shut throttle, brake, change direction, open throttle or something of that Ilk. Plenty of time for that later.
Posted: Tue Jun 05, 2018 9:52 pm
by mechman
The latest on the Hunslet
Fixed the fuel filter to find no fuel getting through so blew the lines out, the, main one was blocked solid, next was bleed the 2 fuel filters on the engine block to find the first filter housing bleed screw was only held in with PTFE tape. removed the housing and the threads were gone completely so tapped out to 3/8 BSF, boxed it all up today to find the old battery they gave me was duff so they (railway) gave me another one, duff as well, both batteries were Yuesa and both 8 years old, so it was coat on time today and see what happens in the next episode. The 2 gauges show the miles covered and the hours.
Posted: Wed Jun 06, 2018 1:11 am
by mechman
Just discovered it has 2 speed forward and reverse, so I'd guess slow and very slow .
Posted: Wed Jun 06, 2018 7:23 am
by Jeremy Rowland
Good going Norman
must say I'm not struck on Yuasa as a make of battery they are Yuasa-less in my opinion, not a good brand never done much good with them as motorbike batteries.
Posted: Wed Jun 06, 2018 12:01 pm
by mechman
The engine is a Dorman 4LB. The info I've managed to find on it is, 4 Cyl , just under 6.4 Ltr, 74 BHP at 1800 REVS. It's a fair size lump, so does any one know what size battery should be used on it, amp hours or whatever? It's a 12 volt system and it looks a though it's only had 1 battery on it.
Norm.
