Hunslett shunter
Discuss rail plant equipment in this forum.
Re: Hunslett shunter
Post #11 by Jeremy Rowland » Thu Jun 07, 2018 10:50 pm
mechman wrote:The engine is a Dorman 4LB. The info I've managed to find on it is, 4 Cyl , just under 6.4 Ltr, 74 BHP at 1800 REVS. It's a fair size lump, so does any one know what size battery should be used on it, amp hours or whatever? It's a 12 volt system and it looks a though it's only had 1 battery on it.
Norm. :?
This engine is the same one that's fitted to a couple of the Priestman cranes at Andrew Beaulah's I asked him what battery to fit? He said any decent size truck battery that will fit in the space allocated for it. :thumbup:
mechman
Real name: norman orrick
Has thanked: 144 times
Been thanked: 132 times
Post #12 by mechman » Fri Jun 08, 2018 12:39 am
except Yuasa?
Post #13 by Jeremy Rowland » Fri Jun 08, 2018 7:36 am
mechman wrote:except Yuasa?
You got it :lol:
mechman
Post #14 by mechman » Sat Jun 16, 2018 5:42 pm
The latest is I got it running this afternoon, not without a few snags (wouldn't be any fun otherwise) put a few pics up, all of it running. The excess fuel return pipe to the tank is badly corroded (leaking badly so that needs replacing (another day) but the engine is as sweet as a nut. Apparently It's been stood for 8 years.
Norm :D
Post #15 by Jeremy Rowland » Sat Jun 16, 2018 7:20 pm
Well done Norman keep up the good work. :claphands:
mechman
Post #16 by mechman » Tue Jun 19, 2018 11:43 pm
The latest
Been wrestling with the charging system today because it isn't We've narrowed it down to the dynamo, had a look at the brushes etc and it's brand new in there so it's over to someone that knows, :dizzy:
Norm.
Post #17 by Jeremy Rowland » Wed Jun 20, 2018 8:07 am
Electrics are something that I struggle with hope you get it sorted :thumbup:
mechman
Post #18 by mechman » Thu Jun 21, 2018 11:21 am
Latest
The dynamo is off the loco now and is going to be checked by some people in the know (allegedly) Can the dynamo lose its magnetism after long periods of inactivity?
Norm :? :?
Post #19 by Jeremy Rowland » Thu Jun 21, 2018 9:32 pm
mechman wrote:Latest
Norm :? :?
Norman the dynamo has field coils similar to an electric motor I would suspect if there is an issue with it then the armature and brushes are the most likely culprit. :thumbup:
mechman
Post #20 by mechman » Thu Jun 21, 2018 9:57 pm
If I wire the dynamo to the battery should it run like an electric motor and if it spins does that mean it's OK?
Norm :? :?
Return to “Rail Plant Equipment”
Users browsing this forum: No registered users and 46 guests
