Im not that worried about the trucks ,could i turn up with my Taurus tracked loader and meet a few different people.
I may have given the impression that i am only interested in trucks but i enjoy plant and tractors as well, in fact anything that moves as long as youre not expected to polish it.
Dick Bryant.
BTD6 Drott
- Real name: dick bryant
Re: BTD6 Drott
i misred your last message and thought you were trying to put me off.ill be blunt,do you want any new members because i could be your man.as previously mentioned i have a bristol taurus in working order and an old kh88 360 that does everything it should do. i also own a yanmar powered tracked dumper that is awaiting an engine trans plant.
Dick Bryant
Dick Bryant
Topic author - Posts: 6393
Re: BTD6 Drott
Would love to see you join the Link club Brian,you dont have to own a Cat to join us.
Please PM me if you want more details.Your name is familiar.
Regards
Regards
Re: BTD6 Drott
Now that the weather is improving,I wil by trying to sort out the transport of the BTD6
Managed to get hold of lots of Drott spares,
Also hope to get the TD6 home in the very near future.
Re: BTD6 Drott
martyn
its that man again.if transport is a problem then i may be able to help. my truck has a hydraulic beavertail and a sizeable hydraulic winch.
carrying capacity is just short of twelve tons.
dick bryant
dick bryant
Re: BTD6 Drott
What is a pm?
D.B
What is a pm?
D.B
Last edited by Jeremy Rowland on Wed Feb 02, 2011 12:07 am, edited 1 time in total.
Reason: Uppercase used throughout
- Real name: Gordon Pilmoor
Re: BTD6 Drott
Hi Martyn,
Ive just recently got hold of a Drott B6 K3 (BTD 6), serial number BD 1734 in good working order - Engine number BD 264 65601 if that helps, and would like to do a major overhaul with respect to oils. Jim Stoneman (Dozerman) from Victoria, Aus , advised me to contact you in the hope that you maybe able to give me some oil and fuel filter numbers.
The engine oil filter is a cartridge type located on the rh rear of the engine in a verticle cannister. The fuel filters are Donaldson P55711?? - white replaceable units with end caps - two off.
Interested in any info you can point to me
Regards
Gordon - Mandurah, West Australia email: Gemec@bigpond.com.
Regards
Re: BTD6 Drott
Will email you some filter numbers soon. Keep us posted on your progress. Before you change the fuel filters I would give the fuel tank a good cleanout and refill with fresh diesel.Also check the hydraulic pump drive for wear.A common fault on the BTD6 is that the "nose " bolts work loose.Use a trolley jack on the front end and see if there is vertical play.It would also be a good idea to remove the steering clutch inspection plates and inspect for water or brake lining debris.
Regards
Regards
Re: BTD6 Drott Starter Motor Issue
With reference to Drott B6 K3 -engine BD264, engine number 65601, I am now experiencing Starter motor problems with a likely rebuild or replacement.
Can anybody advise if there is an after market model replacement or substitute unit to the OME.
Gordon
Gordon
