B100 Update
Discuss track loaders here
Has thanked: 1295 times
Been thanked: 1111 times
Re: B100 Update
Post #11 by FOWLER MAN » Tue Mar 03, 2015 3:03 pm
Britman wrote:Could you tell me why you didn't compress the clutch with the proper bolts.It is a much easier way .
I'm curious too :?: :?:
sphill
Real name: Simon Hill
Been thanked: 2 times
Re: B100 Update
Post #12 by sphill » Fri Mar 06, 2015 6:31 pm
I have only got an extract from a TD6 manual for the steering clutches and it showed the use of the clamp type compressor so that is what I did. I take your point that using the bolts would have been much easier but not having ever tackled a steering clutch before I was reluctant to just screw a long bolt into it not knowing what it may be bearing against. Now that I have dismantled the clutches I can see where the bolts go and so needless to say that is how I shall compress the clutches when it comes to installing them.
Thank you for your concern and suggestions, with hindsight I should have probably have asked first but no harm done and we learn by our mistakes. Incidentally the clamps work but are a bit fiddly to fit and tighten up.
Thanks Simon.
Re: B100 Update
Post #13 by FOWLER MAN » Sat Mar 07, 2015 11:36 am
Hi Simon,
Some of the early T6 /TD6 crawlers were'nt drilled for the compression bolts, hence the Clamp type compressor.
You will probably be aware by now that the bolts are 7/16 UNC. (5/8 AF spanner).
From memmory they are about 2-1/4" long and need to have a spiggot turned on the end to reduce the diameter to about a 1/4" , again from memmory the spiggot is about 3/8" long. That should work anyway.
Hope this helps if you didn't already know.
Britman
Real name: Peter Sulley
Re: B100 Update
Post #14 by Britman » Sun Mar 08, 2015 12:15 am
P.S. Do not forget to tighten the bolts a little at a time or you will break the plate that they push on.
martyn williams
Real name: MARTYN WILLIAMS
Has thanked: 296 times
Been thanked: 359 times
Re: B100 Update
Post #15 by martyn williams » Mon Mar 09, 2015 9:10 pm
I have some bolts made up for compressing the clutch same as Fred says.It works ok. Will be stripping out my TD6 clutches soon.Been a bit manic at the moment
sphill
Re: B100 Update
Post #16 by sphill » Wed Mar 11, 2015 7:11 pm
Hi
I have made some bolts to Fred's description and I have to agree that they work much easier than the clamps. I have cleaned up and reassembled one of the clutches and it seems pretty good, I'll get my son to do the other one. We have now got the engine parts required so should be able to start rebuilding that soon as well.
Simon
Return to “Track Loaders”
