Terex will introduce a new line of skid steer loaders - both vertical lift path and radius lift path models - to add to its range of compact equipment. There are eight models, with engine sizes from 37.5 kW to 62.2 kW, and Terex highlights the high ground clearances and rear angles of departure of the machines - 265 mm ground clearance and either 26 degree or 29 degree rear angles of departure, depending on the model.
The range includes four radial lift path models (TSR50, TSR60, TSR70 and TSR80) and four vertical lift path units (TSV50, TSV60, TSV70 and TSV80
Source: http://www.khl.com/magazines/international-rental-news/detail/item62056/new-compact-machines-from-terex/
Terex enter skid steer loader market
