Evening all.
Had 2 days with no electrics or phone due to bad storms here in SW France. Got plenty done on the old JCB though.
Emptied out the ATF sump, removed the filter and gave everything a good clean. Some bits of swarf but nothing too bad. Put 12 litres of Dexron ATF back in (€8 A LITRE
) and now the T/C pressure reads between 9-10 Bar (120-125PSI) - the old girl goes like a train now... still a 2 second delay when engaging forward or reverse though.
Topped up with another 10L hydraulic fluid (50 total so far) and finally got a level in the plastic indicator tube in the cab
. The loader bucket and backhoe feel much better now, as does the steering action
Talking of steering, I assume there should be some rubber bushes at each end of the steering arm connecting the 2 front wheels
If YES, then mine have probably worn away and never been replaced. Anyone have any ideas where I can get a pair...
Thanks again to everyone who offered advice/suggestions
Je vous remercie
Eamonn
