Changing ram seals on 3CX rear legs
Topic author - Posts: 806
- Real name: David
- Has thanked: 76 times
- Been thanked: 179 times
I need to change the seals on the rear leg ram on my 3cx anyone got an easy way to do this, i can't quite see how to take the foot off the leg to enable me to remove the ram, the top looks easy enough to disconnect.
- Real name: phil wheelton
Re: Changing ram seals on 3CX rear legs
The bottom bolt should be in a hole in the leg sleeve , it should be 9/16 AF (3/8 unf bolt ) the ram should lift out of the leg... but if it is packed in with mud and dried around you might have to take the whole leg out of the bottom of the frame.
