Im not real flash on these tractors I know some had a up draft carby but if you operate the carby ie open the throttle is it putting fuel in is the accelerator pump working ?
can you give it a good squirt of fuel in the inlet manifold and wind it over if it still dosnt fire I would feel you have a spark problem
ferguson timing
- Real name: Paul Griffiths
- Has thanked: 384 times
- Been thanked: 256 times
Re: ferguson timing
Yes I've not tried that, I did try the dreaded easy start in the carb intake and nothing whatsoever so could be a blockage somewhere, I'll give that a try, thankyou for the advice, Martin
- Has thanked: 1887 times
- Been thanked: 1701 times
Re: ferguson timing
Martin what is the state of the distributor cap? Sometimes you can have a good spark at the plugs but if there is a hairline crack in the cap it can easily track to earth, which would be easier than jumping the spark plug gap when the plug is in the cylinder under pressure.
These are just some suggestions to try and help out; there is one last thing and this did happen to me with an old car that I had years ago; I had changed all of the things that you have changed but the car was not running right it would still occasionally misfire, then one night it broke down and I managed to get it to 'limp' home.
I found that although I had fitted a new capacitor and points, the new capacitor was faulty and turned out to be the cause of the woes all along. Problems like this are most irritating because when you have changed something for a new part then you automatically rule it out of the equation when fault finding.
When all is said and done it is a petrol engine and if it won't run then its normally either a lack of fuel or a lack of a decent spark.
Re: ferguson timing
Ok I'll check this out too, cap appears really good but I'll check it over once I've refitted the carb again and tried the gravity feed, I'll keep u posted, Martin
- Real name: Norman
- Been thanked: 15 times
Re: ferguson timing
You say you have fitted a new float and needle valve to the carb but are they definately set correctly. Is the float free to move?
When you open the carb up again is the float chamber nearly full? It will need a certain amount to cover the jets before fuel is sucked through into the throttle body area.
Is the vent/ overflow to the float chamber free of blockage? If air can't get in fuel can't be sucked out.
Re: ferguson timing
Could be onto something here, I didn't notice any vent holes in float chamber ill take a closer look.
