Butler Drott lights
martyn williams
Real name: MARTYN WILLIAMS
Has thanked: 296 times
Been thanked: 356 times
Butler Drott lights
Post #1 by martyn williams » Sat Feb 04, 2012 11:24 am
I have had a few phonecalls about getting spares for Butler lights as fitted to Drotts.
What I have found is that the internals off other lamps will fit a Butler casing.
This is what I do
Strip all the internal light fittings such as the reflector ( these are usually rusted ) and lamp holder,they are held in place with clips.
Clean the lamp casing and grill,repaint if required
Obtain a fordson major lamp,complete unit is less than £20 from Dunlope tractor spares
Remove the internals from the fordson lamp casing.
You will find that the complete lamp internals will fit the Butler lamp casing reuse the Butler lense if not damaged,just a clean may be required.
You will find that the Fordson lamp may be high or low beam.I wire it to high beam,this gives a good bright light.
This has worked well on a few machines now :thumbup:
Will post photos when I overhaul the next set.
martyn williams
Re: Butler Drott lights
Post #2 by martyn williams » Sat Feb 04, 2012 2:35 pm
Refurbished lamps fitted to the 100
martyn williams
Post #3 by martyn williams » Sat May 26, 2012 5:01 pm
Easy and a cost effective way to restore Butler Drott lamps.
Return to “Tech Talk”
