UNF bolts required (UK)
Julian
Real name: Julian
Been thanked: 11 times
Post #1 by Julian » Mon Mar 21, 2011 9:36 pm
Specifically I'm after buying grade 8 bolts (machine screws would do) of 5/8th dia 1 3/4'' length.
I'm struggling finding a supplier, regular grade S or the SAE grade 5 (equivalent to metric grade 8.8 ) are easy enough. The nearest I found was a manufacturer in the midlands who had the blanks and would make me several thousand - I only need 8.
Anyway, I know there's a few here working within engineering so any pointers gratefully received thanks.
The other alternative would be M16's grade 10.9 (the equivalent strength) but these too may be difficult to source and would require me getting approval for their use first, something I'd like to avoid!
Cheers Julian.
martyn williams
Real name: MARTYN WILLIAMS
Has thanked: 296 times
Been thanked: 356 times
Re: UNF bolts required (UK)
Post #2 by martyn williams » Mon Mar 21, 2011 10:33 pm
Try Williams fastners,they will be able to help. I have used this firm and they are helpfull
http://www.williamsfasteners.com/news.htm
Ian Fletcher1970
Real name: Ian Fletcher
Has thanked: 534 times
Been thanked: 148 times
Contact:
Post #3 by Ian Fletcher1970 » Mon Mar 21, 2011 11:48 pm
Try these - I've used them and they are very helpful and fast delivery
Ian
http://www.namrick.co.uk/
Has thanked: 1431 times
Been thanked: 1269 times
Post #4 by Jeremy Rowland » Tue Mar 22, 2011 8:46 am
Here's a supplier that I use at work and they still seam to be able to get hold of old redundant fasteners like UNF/UNC BSF/BSW and specials.
West Bromwich Fasteners Ltd
Tel 0121 520 6050
Hope that helps.
Julian
Real name: Julian
Post #5 by Julian » Tue Mar 22, 2011 11:33 am
Thanks chaps, I had a brain wave just now and tried e-bay USA, got them ordered! :D
All the suppliers (including Namrick which I've used for years) only stock regular high tensile stuff, ie metric grade 8.8 or imperial sae grade 5 or the old grade S.
The best I did yesterday was find a bolt manufacturer in the midlands who had the blanks - wanted a minimum run of about 10,000 no doubt!
Julian.
martyn williams
Post #6 by martyn williams » Tue Mar 22, 2011 12:29 pm
I was after track bolts for a Drott,they worked out over £1 for a nut and bolt :dizzy:
So if anyone out there knows for trackbolts,please let me know.
Has thanked: 1165 times
Been thanked: 1029 times
Post #7 by FOWLER MAN » Tue Mar 22, 2011 11:28 pm
Hi Martyn,
Talking about pad bolts, that may have been the answer to Julians search.
The standard 5/8 UNF pad bolt is 2 1/4 inches long, tensile strength 12.9 I've got some on the shelf.
We used to use them on the Barber Greenes to attatch the conveyor scraper bars to the chains too, everything else would shear but pad bolts cured the problem. They were all stamped with either a V or 12.9.
What size are on your Drott, I still have a few 1/2 inch.
martyn williams
Post #8 by martyn williams » Wed Mar 23, 2011 10:28 am
Hello Fred,I think its 7/16,1/2" , 2" long with square nut. 3/4 "square.. bolt head 9/16"
Return to “Tech Talk”
