How Difficult Is It To Overhaul The Brakes?
Topic author - Posts: 46
- Real name: Michael Fox
- Has thanked: 3 times
We have an old JCB 3 Mk II and the brakes are nearing the end (about 20 years ago ). How much of a job would it be to overhaul them? Can you go in through the top like with the clutch?
- Real name: phil wheelton
Re: How Difficult Is It To Overhaul The Brakes?
If you take the floor plates up the brakes are at the top of the half shaft housings just undo the 9/16 af headed bolts on the end plates slacken the adjusters off (3/4 af ) there are 2 brake plates with the expander in between them,It's not too much of a hard job you might need some easing oil to get the clevis pins out.
I did the brakes on my 3c a couple of year's ago and is well worth doing, if you go on the Leyland/Nuffield forum there are quite a few thread's on brakes
- Has thanked: 4 times
As suggested above. Give all the brake shafts a good grease whilst you are underneath as mine was seized solid when I went into fix my brakes!
Remember that asbestos was about 20/30 years ago, so wear a mask, etc when cleaning out the housing. I had a lot of dust in mine.
