Is this repairable? JCB3 III
Topic author - Posts: 26
- Real name: Jon Dobson
I've been offered this cheaply - it looks like it has been repaired before, is this repairable do you think?
- Real name: phil wheelton
Re: Is this repairable? JCB3 III
If its cheap you should be able to get a dipper and ram from one of the breakers
Its repairable using a press and V blocks,but you should be able to get a replacement.
- Has thanked: 7 times
- Been thanked: 43 times
Yeah the replacement route is the way to go. A dipper is £200 and a dipper ram is £40.
William
JCB Hydra Digger Loadall 65
JCB 3DIII Powertrain
JCB 3DIII (Manual)
JCB 3DII
JCB 3CIII
JCB 805B
JCB 3DIII (Manual)
JCB 3DII
JCB 3CIII
JCB 805B
- Real name: martyn henley
- Has thanked: 38 times
- Been thanked: 50 times
Many thanks to Phil,Martyn, William and Martyn Henley for your invaluable advice, I will add the sums up and make a decision on purchase. Are these parts readily available.
Once again thanks
Once again thanks
These parts are very common hence the cheap prices. A 2D/3 boom could be hard to find.
William
JCB 3DIII (Manual)
JCB 3DII
JCB 3CIII
JCB 805B
JCB 3DIII (Manual)
JCB 3DII
JCB 3CIII
JCB 805B
The pin hasn't been bolted in and the constant working action of the dipper ram has "worked" the pin to slide out of the cuff.
William
JCB 3DIII (Manual)
JCB 3DII
JCB 3CIII
JCB 805B
JCB 3DIII (Manual)
JCB 3DII
JCB 3CIII
JCB 805B
