3D II tacho
- Real name: john
- Been thanked: 6 times
Re: 3D II tacho
just a thought,
would this be the same angle drive, cable as found on a leyland tractor with the same engine?
1982 3CX4 sitemaster
Topic author - Posts: 183
- Real name: Brian
- Been thanked: 30 times
Re: 3D II tacho
jcb1968 wrote:just a thought,
Probably, but it needs to be the correct length. 92" i believe.
- Real name: Julian
- Been thanked: 13 times
Re: 3D II tacho
mambo wrote:Yeah, never thought of that would that not make it thinner though?
Thinner or fatter - depending on how you measure
About two years ago i replaced the speedo cable in my series Landrover with a Brit (shit) part item. Rather than a nice squared off ends to engage the females in the speedo head and gearbox it just had the ends flattened so they would catch two corners of the drive
Julian (never knowlingly buys Shitparts Landrover bits ever again)
- Real name: James
Re: 3D II tacho
Hi All,
Read with intrest the posts. I replaced my tacho drive and cable and the tacho worked fine until the engine oil travelled up the cable and into the tacho itself! The tacho wound itself right around to a full rev reading every time i connected the cable. I haven't got round to looking at the tacho to see if any damage has been done Is anyone repairing these tacho's?? I think its sub standard parts, there must be some sort of sealing at the tacho drive end to stop the oil travelling up the cable?
Happy cable and drives
DJ
DJ
- Real name: Tim Arnold
- Been thanked: 2 times
3D II tacho
Took the cable off of mine at the weekend. Broken in the middle, trouble is cant find a replacement, digger parts suggested I try Paul but his phone just rings and goes dead, no reply to email (
Speedograph in Nottingham say on their website they will copy any pattern, also if any one needs it they refurbish instruments
Sent from my iPad using Tapatalk HD
Tim Arnold
http://www.parklandsholidays.co.uk
JCB 3D3, Benford 1ton Dumper, Benford Pedestrian Roller.
- Real name: Brian
Re: 3D II tacho
Hi Tim
Does your Tacho cable come from the drive on the timing cover behind the fan? If so Paul Martin doesn't have any (i rang him last week)
He only has the shorter ones
3D II tacho
Ok I have made contact with speedograph in Nottingham the approximate cost will be £30 + vat, before I send the old one as a pattern and place an order is anyone else interested, don't think there will be any saving but will save the agro of having to send another pattern to copy. I am away from home till Tuesday but plan to send off my old cable as a pattern and place an order then. If you are interested pm me a contact number.
Tim Arnold
Users browsing this forum: No registered users and 31 guests
